adnan019
Fill a column vertically from two different data table
Hi
I am new to JSL. I have to merge to columns vertically to a new column something like below. Any help is appreciated.
uday_guntupalli
Level VIII
Re: Fill a column vertically from two different data table
@adnan019 ,
     There are multiple ways to do this. I will show you a few:
// Create Data  Set 1
dt = New Table("Character Data");
dt << New Column("CharacterSet",Character,Nominal,<< Set Values({"A","B","C"}));
// Create Data Set 2
dt1 = New Table("Numerical Data");
dt1 << New Column("NumericalSet",Character,Nominal,<< Set Values({"1","2","3"}));
// Approach -1
dt2 = dt1 << Concatenate( dt);
dt2 << New Column("ConcatenatedData",Character,Nominal,Formula(If(IsMissing(:CharacterSet),:NumericalSet,:CharacterSet)));
// Approach - 2
ValsFromTable1 = dt:CharacterSet << Get Values;
ValsFromTable2 = dt1:NumericalSet << Get Values;
AllData = ValsFromTable1 || ValsFromTable2;
dt3 = New Table ();
dt3 << New Column("ConcatenatedSet",Character,Nominal,<<Set Values(AllData));
 Note that I modeled the numerical data as character, this is to enable the concatenation
Best
Uday
Or interactively:
First make sure the data type is for both columns character (or at least the same), otherwise concatenation won't work.
  • Using tables menu, "stack" will do what you want. Select your two or whatever number of columns and drag them on the "Stack Column" role.
  • Deselect "Stack by Row" to have a true concatenation
    That's it.
And of course in the Source Script of the table you find the JSL approach:
Data Table( "MyData" ) << Stack(
	columns( :Col 1, :Col 2 ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" ),
	Stack By Row( 0 )
I like the others from Uday, too.
Best
Martin
uday_guntupalli
Level VIII
@adnan019 ,
// Approach -1
// Approach - 2
dt3 = New Table ();
Best
Uday
Or interactively:
    That's it.
	Stack By Row( 0 )
Best
Martin
adnan019
Thanks Martin. Interactively that is also helpful.
adnan019
Thanks. The || sign worked for me.
