Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
SIBH
File save as .csv format keeps failing from version to version
Dear All,
I have one script to save data table automatically as .csv. This works for few JMP14 or 15 users, but fails for few JMP15 users. same script runs behind all types of data table save. I tried both, with or without 'convert file path' but cant get to the real reason behind it.
Thanks ! Simanti.
save_csv_file = Function({dt},
	try(
		path = Pick Directory ("Select a directory.");
		print(path);
		New Window( "Specify filename",
			<<Modal,
			file_name = Text Edit Box( "", <<Justify Text( Center ), << Set Width(200) );
		name_dt = file_name << Get Text();
		dt << Save As (Convert File Path( path || name_dt || ".csv")); //this is working
		//dt << Save As ( path || name_dt || ".csv"); // this is working too :)
		//print(path || name_dt || ".csv");
		New Window( "Success!",
		<<Modal,Text Box("Your file was saved with success!"));,
		New Window( "Ups!",
		<<Modal,Text Box("We were unable to save your file, try again!"));
Re: File save as .csv format keeps failing from version to version
The section of the code
			<<Modal,
fails in JMP 15 for me. But if you change the code to:
	try(
		print(path);
			<<Modal,
			file_name = Text Edit Box( "", <<Justify Text( Center ), << Set Width(200),
			<<set script(name_dt = file_name << Get Text();) );
		dt << Save As ( path || name_dt || ".csv"); //this is working
		New Window( "Ups!",
it works in both 14 and 15
Thierry_S
Is it possible that the Save As command fails because a file with the same name exists in the target directory? If it is a possibility, you may want to test if the file exists (File Exist (path)) to let the user know.
Just a thought.
Best,
TS
Thierry R. Sornasse
Adding to @Thierry_S's suggestion, what if you isolate the Save As() message (forget the function for now) and make sure that it works on its own?
SIBH
Hi @markbailey , This function separately is working in my system and few other person's system too. I will check it in the system of the people who have fail issues. Thank you, Simanti
			<<Modal,
	try(
		print(path);
			<<Modal,
		New Window( "Ups!",
SIBH
Thank you @txnelson , now the script is working perfectly, with the changes you've suggested.
Thank you again.
SIBH
Thank you @Thierry_S, that is very relevant suggestion, I will include it. However, there is no pre-existing file in the target directory.
