pamplemousse
Exporting a 3D surface plot as a high-resolution vector graphic?
I'm using JMP 10 on Mac OS X 10.6, and have had no problems exporting my 3D surface plot as a PNG or TIFF.
However, when trying to export it as a vector graphic (SVG or EPS), the resulting image is always an empty frame. It appears that the selection tool will not select my 3D surface plot  - even when I use the "select all" function; this problem does not occur for me when using the selection tool on 2D plots.
If someone could help me resolve this issue, it would be tremendously appreciated.
Thanks so much!
