BookmarkSubscribeRSS Feed
bmohl
Community Member
Nov 1, 2017
Export graphbuilder to eps changes properties
I'm encountering a number of changes to the graph, when I export to an .eps on the Mac version 13.2.0.
Could someone suggest how to pad the axes (perhaps with a ScaleBox property), so that the titles are not cut off in the .eps? Trying to drag the axis title box only adds to the width of the plot area and doesn't change the script.
Is there a way to keep the hatching the same as the graphbuilder version (left on attached shot) instead of changing to solids, when exporting?
Thanks in advance!
