Export for each value in "Local Filter"
I have the following setup:
  • Diagram with "standard" scatterplot
  • x, y Axis stay the same
  • The content changes according to the selected data filter value
  • Title should change according to the selected local data filter
Now I need to export one image file for every possible entry in the data filter. If there are
10 values in the datafilter, 10 images should be produced. All with the title of the entry in the datafilter. AND
the Header has to change (Replacing Matrix1 with the value in the data filter)
Could somebody tell me how to do that?!?
Thanks Michael
Jeff_Perkinson
Re: Export for each value in "Local Filter"
Hi Michael,
You can use your data filter column as a By() column in a Graph Builder script.
Open( "$SAMPLE_DATA\Big Class.jmp" );
Graph Builder(
  Variables( X( :weight ), Y( :height ) ),
  Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) ),
  By( :age )
That will give you each of the graphs that you're looking for. Then you can save them as you will.
-Jeff
-Jeff
