News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
rossjason
Excluded Row not working in Marker By Column script
I'm trying to color and mark by a column using jsl script. The plan is to have different buttons in a window, each would mark the data in a graph builder by different columns by running the below script. The issue is, my data is usually filtered before this and for some reason the Excluded Rows (1) included in the Marker By Column command doesn't seem to be doing anything to mark the excluded rows. In contrast, if I run the Rows > Color or Mark by Column... tool and essentialy do the same thing and check Excluded Rows, that one works. So what's wrong with the jsl script verses the dropdown tool?
dt = Current Data Table();
dt << Marker By Column(
:metro_tool,
Marker( 1 ),
Color theme( "JMP Dark" ),
Marker Theme( "standard" ),
Excluded Row( 1 ),
Make Window With Legend
Re: Excluded Row not working in Marker By Column script
Oops....my bad.....I copied the wrong code....the issue is
    Excluded Rows( 1 )
not
    Excluded Row( 1 )
dt=current data table();
dt << color or Mark by Column( :age,Marker(1) ,
Excluded Rows( 1 ),
I believe the function you want to use is
     Color or Mark by Column()
dt << color or Mark by Column( :Metro_tool,Marker(1) ,
Excluded Row( 1 ),
rossjason
It's doing the same thing, same problem. Excluded Rows only works if you use the tool dialog box
    Excluded Rows( 1 )
not
    Excluded Row( 1 )
Excluded Rows( 1 ),
rossjason
Ok yeah it was a typo, thanks!
