drdrf
Excel from journal
Is there a way to link to an excel file from journal so that the link opens the excel file?  I am probably missing something very obvious, but every way I have tried results in JMP trying to import the excel spreadsheet into a new JMP data table.
I am using JMP 17.
Re: Excel from journal
One option is to use Web() command for that
nw = New Window("",
	Button Box("Open",
		Web("$SAMPLE_IMPORT_DATA/Team Results.xlsx")
nw << journal;
nw << close window;
Run Program() is a good other option but it is more complicated to use
Do you want to open the Excel file as a JMP data table, or do you want to open the Excel file in Excel?
drdrf
I want to open the file in Excel
nw = New Window("",
	Button Box("Open",
nw << journal;
nw << close window;
