BookmarkSubscribeSubscribe to RSS Feed
Excel add-In 2016 Excel Profiler
JospehK
New Contributor
Aug 11, 2017
How do I enable the JMP add-In for excel? I am currently using Excel 2016 and there is an error which show Load Behavior: Not Loaded. A runtime error occurred during the loading of the COM Add-In.
Byron_JMP
Apr 26, 2012
There are a couple of ways this can get sideways. I'd chek in with JMP Tech Support ( https://www.jmp.com/en_us/support/technical-support-services.html )  they have a bigger library of common issues and will likely be able to get things sorted out for you pretty quickly.
JMP Systems Engineer, Pharm and BioPharm Sciences
JospehK
New Contributor
Aug 11, 2017
Hi Byron, Thanks for referring me to the right platform. Zhi Wei from Technical Support Team has helped me resolved the issue.
