tsolomon
Evaluating an expression with where function and displaying output
Hi, I am making a series of graphs from a data table which are separated based off variable names in another table. Basically when I make a bivariate graph of y vs x, the by is selected from another table of names. I put the graphs in a lineup box but I can not get the where to use the actual values which the variables represent. In addition, a separate text box appears above the graphs with the where designated instead of displaying in the graph title. Basically, I see Where(:Parameter == CofA_dt10:Parameter[w]) but I would like to see the expression evaluated for the different values of w so we know which variable the graph represents. I have tried multiple variations of eval, eval expr and parse and can not get the test to display the way I want. My code is below, any suggestions would be greatly appreciated. It doesnt display with the EVAL function included as below, if I delete the EVAL function, the window will display but with the problem described above.
CofA_dt10 = Data Table( "GraphData" ) << Summary(
Group( :Parameter ),
Freq( "None" ),
Weight( "None" )
output2 = lineup box(Ncol(1));
row_count = nrow(CofA_dt10);
for(w=1, w<=row_count-1, w++,
output2 << append (CofA_dt9 << Bivariate(
Y( :test_value ),
X( :received_date ),
Where( :Parameter == Eval(CofA_dt10:Parameter[w])),
Dispatch(
"Bivariate Fit of CofA Parameter Value By received_date",
OutlineBox,
{Set Title( "CofA Material Parameter Value By received_date" )}
Dispatch( {}, "1", ScaleBox, {Label Row( Label Orientation( "Angled" ) )} ),
Dispatch( {}, "test_value", TextEditBox, {Set Text( "Value" )} )
); //end row loop
tsolomon
Re: Evaluating an expression with where function and displaying output
Hi Uday, that did not work; I am unable to evaluate the expression in the
where statement. However, I modified the code you sent me and I am able to
evaluate the expression within the graph title. If I find a way to delete
the text box above the graphs with the following "Where(:Parameter == Eval(
Parse( Eval Insert( "Stmt" ) ) ))" then this should be an acceptable
solution. I am still curious why this works in the graph title but not in
the where statement but that is for my own understanding.
CofA_dt10 = Data Table*(* "GraphData" *)* << *Summary(* Group*(* :Parameter
*)*, Freq*(* "None" *)*, Weight*(* "None" *)* *)*;
output2 = Lineup Box*(* N Col*(* *1* *)* *)*;
row_count = N Row*(* CofA_dt10 *)*;
For*(* w = *1*, w <= row_count - *1*, w++,
Stmt = CofA_dt10:Parameter*[*w*]*;
output2 << *append(*
CofA_dt9 <<
Bivariate*(*
Y*(* :test_value *)*,
X*(* :received_date *)*,
Where*(* :Parameter == Eval*(* Parse*(* Eval Insert*(* "Stmt" *)* *)* *)*
SendToReport*(*
Dispatch*(*
"Bivariate Fit of test_value By received_date",
OutlineBox,
*{*Set Title*(* "CofA Parameter Value By received_date" ||" " || Eval*(*
Parse*(* Eval Insert*(* "Stmt" *)* *)* *)* *)}*
Dispatch*(* *{}*, "1", ScaleBox, *{*Label Row*(* Label Orientation*(*
"Angled" *)* *)}* *)*,
Dispatch*(*
"test_value",
TextEditBox,
*{*Set Text*(*
"Value"
uday_guntupalli
Level VIII
@tsolomon
     What you might want to try is this:
CofA_dt10 = Data Table( "GraphData" ) << Summary( Group( :Parameter ), Freq( "None" ), Weight( "None" ) );
output2 = Lineup Box( N Col( 1 ) );
row_count = N Row( CofA_dt10 );
For( w = 1, w <= row_count - 1, w++,
	Stmt = CofA_dt10:Parameter[w];
	output2 << append(
			Y( :test_value ),
			Where( :Parameter == Eval(Parse(Eval Insert("\[Stmt]\")) ) ),
				Dispatch(
					OutlineBox,
); //end row loop
You essentially want to wrap the eval with an Eval Insert and Parse
Best
Uday
tsolomon
Thank you Uday but unfortunately, that still doesn't work for me. the title
of the graph appears as "
Where(:Parameter == Eval( Parse( Eval Insert( "Stmt" ) ) ))" instead of
displaying Stmt for each graph. I am using JMP 12 if that makes a
difference.
Cheers,
Tesfu
uday_guntupalli
Level VIII
@tsolomon,
  One edit, I think this might work, if not please let me know and I will take a look at it
	output2 << append(
			Y( :test_value ),
		        Eval(Parse(Eval Insert("\[Where( :Parameter == [^Stmt^]\")) ) ),
				Dispatch(
					OutlineBox,
); //end row loop
Best
Uday
tsolomon
CofA_dt9 <<
Bivariate*(*
SendToReport*(*
Dispatch*(*
OutlineBox,
Dispatch*(*
"test_value",
TextEditBox,
*{*Set Text*(*
"Value"
