winfriedkoch0
Estimation of model predicted survival time
The JMP procedure "Fit parametric survival" has a lot of options. Is there a possibility to get the model predicted survival time for each observation?
jiancao
Re: Estimation of model predicted survival time
Select Save Quantile Formula option and enter a probability value ( e.g., 0.5 for median failure time), a new column, Fitted Failure Quantile, will be saved to your data table. That's the predicted survival time for the corresponding quantile (e.g., median failure time).
jiancao
Article Labels
