Botzal
Error - Importing excel (365)
I'm trying to import excel (365) file, and I can't do it.
I'll mention that until I've updated the Office to 365 everything worked fine.
Someone's having a similar problem or someone has a solution?
Open(
"C:\Desktop\namefile.xlsx",
Worksheets( "Sheet1" ),
Use for all sheets( 1 ),
Concatenate Worksheets( 0 ),
Create Concatenation Column( 0 ),
1,
Has Column Headers( 1 ),
Number of Rows in Headers( 1 ),
Headers Start on Row( 2 ),
Data Starts on Row( 3 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 0 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Treat as Hierarchy( 0 )
Thx
6 REPLIES 6
Jeff_Perkinson
Re: Error - Importing excel (365)
Are you getting an error message? What happens when you try to import the file?
-Jeff
Botzal
hi Jeff,
yes, I getting an error message.
see attached.
Just a thought: is the file still open in Excel? If so, close out of Excel. Maybe that would fix it?
Dan Obermiller
Botzal
Hi Dan,
Yes, it's an Excel file.
The file is closed and it still doesn't work.
I think you may need to contact JMP Technical Support.
Dan Obermiller
Botzal
I tried to import the Excel file in JMP 11 and it didn't work,
but I tried to import the same file in JMP 14 and it works! :)
I don't know what the problem was but it works.
Thx to all for the support.
