BookmarkSubscribeRSS Feed
derchieh
Equivalence test in Nonlinear Model
Just wondering how the Confidence Limits for Ratio are calculated for the Equvalence Test in Nonlinear Regression with Built-In Models.
Below is an example using data provided by Russ Wolfinger in his post on Bioassay 28 May 2014.
Equivalence Summary
Level                         Lower CL     Ratio            Upper CL     Limit Exceeded\
Growth Rate               0.9293       1.1373          1.3452          Upper
Inflection Point            0.8498       0.8685          0.8872
Lower Asymptote        0.9592       1.0794          1.1996
Upper Asympotote      0.9890       1.0488          1.1086
Many thanks in advance.
Regards,
Derchieh
