vince_faller
Encrypting Decrypting with Powershell
I'm trying to encrypt a list of valid JSL using runprogram/powershell.  It's important that this is only a single call to powershell because of performance.  I thought I had it working but realized that single or double quotes messes me up when they're nested lists.
Also, I can NOT write to a file and have powershell read that.  works great, not allowed to do it though.  I think I'm just broken on the escaping of JSL and C and Powershell.
Names default to here(1);
encryption_key = J(16, 1, randominteger(0, 255));
unencrypted_input = {"Fa'ke\!"", {Empty(), "Str'\!"ing"}}; // this one breaks me
unencrypted_input = {"Fake", {Empty(), "String"}}; // this one is fine
print("encryptng");
init_str = "@("; // creating a powershell array
for(i=1, i<=nitems(unencrypted_input), i++,
	if(i!=1, init_str ||= ", ");
	item = unencrypted_input[i];
	// for encrypt we want to put it in quotes so we can pull it out later so we can parse;
	if( isstring(item), item = "\!""||char(item)||"\!"");
	// because of the way runprogram works we have to C escape the quotes as well
	init_str ||= "\\!""||substitute(char(item), "\!"", "'")||"\\!"";
init_str ||= ")";
exec_str = init_str || " | ConvertTo-SecureString -AsPlainText -Force"
	|| " | ConvertFrom-SecureString -Key " || Substitute(char(encryption_key), "[", "(", "]", ")");
write("\!n"||exec_str);
rp = Run Program(
	Executable("powershell"),
	Options(exec_str),
	ReadFunction("text")
print("");
show(rp);
encrypted_list = words(rp, "\!n\!r");
print("decrypting");
// now to decrypt
for(i=1, i<=nitems(encrypted_list), i++,
	item = encrypted_list[i];
init_str ||= ")";
exec_str = init_str || " | ConvertTo-SecureString -Key " || Substitute(char(encryption_key), "[", "(", "]", ")")
	|| " | ForEach-Object {"// doing this in a loop in case of multiple lines
	|| "$BSTR = [System.Runtime.InteropServices.Marshal]::SecureStringToBSTR($_);"
	|| "[System.Runtime.InteropServices.Marshal]::PtrToStringAuto($BSTR)}";
rp = Run Program(
	Options(exec_str),
print("");
show(rp);
dec_list = Words(rp, "\!n\!r");
for(i=1, i<=nitems(dec_list), i++,
	r = substitute(dec_list[i], "'", "\!"");
	r = parse(r); // parse it because we wrapped everything
	dec_list[i] = r;
show(dec_list, unencrypted_input);
show(dec_list == unencrypted_input);
Vince Faller - Predictum
vince_faller
Re: Encrypting Decrypting with Powershell
I think the crux is with going to/from a powershell array.
Maybe this makes things easier to understand
//unencrypted_input = {"Fa'ke\!"", {Empty(), "Str'\!"ing"}}; // this one breaks me
to_pwsh_array = function({input, wrap_string = 1},
	// wrap string because the inputs for decrypt aren't valid JSL so we don't want to wrap those
	{DEFAULT LOCAL},
	for(i=1, i<=nitems(input), i++,
		item = input[i];
		if( wrap_string & isstring(item), item = "\!""||char(item)||"\!"");
	init_str ||= ")";
from_pwsh_array = function({input},
	final_list = Words(input, "\!n\!r");
	for(i=1, i<=nitems(final_list), i++,
		r = substitute(final_list[i], "'", "\!"");
		final_list[i] = r;
	return(final_list);
rp = Run Program(
	Options(to_pwsh_array(unencrypted_input)),
out = from_pwsh_array(rp);
show(out == unencrypted_input);
ih
Super User (Alumni) ih
Could you substitute the quotes in JSL with something that doesn't include a quote and then substitute them back within powershell using replace?
vince_faller
I tried to do that with [quote], but I couldn't get it to work because of the the way char(list containing strings) works.  I can't get powershell to give me quotes back, it just strips the quotes, so when I pull it back in (if it has quotes inside as well) then it screws up the parse.  I could maybe make a recursive function with depth so that it goes in and turns all things into what I need then only wrap the top level.  If that makes any sense.
ll = {"Fak'e\!"", {Empty(), "Str'\!"ing"}};
char(ll); // "{\!"Fak'e\!\!\!"\!", {Empty(), \!"Str'\!\!\!"ing\!"}}"
ih
I was thinking more like what is below, unless you need to keep the outer list structure in powershell?  I don't think you even need the powershell array unless the encryption function you're using requires it.
	{DEFAULT LOCAL},
	init_str = "@(\\!"" || substitute(char(input),"\!"","[quote]") || "\\!")";
from_pwsh_array = function({input}, {default local},
	notrailingnewline = regex(rp,"(.*)\!N","\1");
	replacedquotes = substitute(notrailingnewline, "[quote]", "\!"");
	parsed = parse(replacedquotes);
	parsed;
checkvalue = function( {in},
	rp = Run Program(
		Options(to_pwsh_array(in)),
	show(in, to_pwsh_array(in), rp, out, in == out);
	in != out;
if(
	sum(
		checkvalue( Expr( {"Fake", {Empty(), "String"}} ) );
		checkvalue( Expr( {"Fa'ke\!"", {Empty(), "Str'\!"ing"}} ) );
	) > 0,
	write("\!N\!NFailed"),
	write("\!N\!NSuccess")
