BookmarkSubscribeRSS Feed
Ellipsoids: change colour manually
andreas_scherer
Jan 18, 2015
Hello, I would like to find out how to set the colour of ellipsoids in a scatterplot manually. I am sorry if this may be an old question but I have not found any solution yet. I simply have a grouped 3d scatterplot and would like to display the contour ellipsoids in colours I chose. Where can I select the colours for the ellipsoids?
KarenC
Feb 10, 2013
Andreas,
If you set the color for your grouping variable in the column properties for that column (value colors) then when you use that grouping variable in the 3D scatter plot the ellipsoids will be the desired colors.  I agree that I don't see the option within the 3D platform, nor does the "customize" dialog box appear to be accessible within that platform.
Karen
andreas_scherer
Jan 18, 2015
This worked very well, Karen. Thank you very much for considering answering my question.
