BookmarkSubscribeRSS Feed
Elevator Bars on Table Boxes?
I have window containing a Table Box. That Table Box displays a set of summary statistics relating to a data table that I select from a list of such tables, and contains as many rows as there are columns in my data table. I don't know in advance how many columns there are going to be in the data table, so I don't know how many rows my Table Box is going to need. This isn't a problem, as the Table Box simply expands or contracts to accommodate the number of rows it contains. However, I want to limit the number of rows to 20 (so that my window doesn't run off the bottom of the screen), and insert a vertical elevator bar to the right of the Table Box if it's needed - in the same way that such a bar will automatically appear on a List Box if the number of elements in the list exceeds the NLINES parameter.
Is this possible? I can't see any property of a Table Box that would enable me to do it directly, and I can't think of a way to surround the Table Box with some sort of frame to which an elevator bar could be attached.
Many thanks for any suggestions.
ms
Jun 23, 2011
Re: Elevator Bars on Table Boxes?
If your tablebox only has a few columns one idea would be to trick a listbox to look like a table box by inserting tabs. See a simple example below. I inserted a conditional egument for the number of tabs to get the impression of a justified table. (this could be improved and generalized, for example by using som regex loops that insert space to match up with longest word in the left column).
Open( "$ENGLISH_SAMPLE_DATA/Baltic.jmp" );
Data Table( "Baltic" ) << Summary(
          Group,
          Mean( :v1 ),
          Mean( :v2 ),
          Mean( :v3 ),
          Mean( :v4 ),
          Mean( :v5 ),
          Mean( :v6 ),
          Mean( :v7 ),
          Mean( :v8 ),
          Mean( :v9 ),
          Mean( :v10 ),
          Mean( :v11 ),
          Mean( :v12 ),
          Mean( :v13 ),
          Mean( :v14 ),
          Mean( :v15 ),
          Mean( :v16 ),
          Mean( :v12 ),
          Mean( :v18 ),
          Mean( :v19 ),
          Mean( :v20 ),
          Mean( :v21 ),
          Mean( :v22 ),
          Mean( :v23 ),
          Mean( :v24 ),
          Mean( :v25 ),
          Mean( :v26 ),
          Mean( :v27 )
dt1 = Data Table( "Summary of Baltic" ) << Transpose(
          columns(
                    :Name( "Mean(v1)" ),
                    :Name( "Mean(v2)" ),
                    :Name( "Mean(v3)" ),
                    :Name( "Mean(v4)" ),
                    :Name( "Mean(v5)" ),
                    :Name( "Mean(v6)" ),
                    :Name( "Mean(v7)" ),
                    :Name( "Mean(v8)" ),
                    :Name( "Mean(v9)" ),
  :Name( "Mean(v10)" ),
  :Name( "Mean(v11)" ),
  :Name( "Mean(v12)" ),
  :Name( "Mean(v13)" ),
  :Name( "Mean(v14)" ),
  :Name( "Mean(v15)" ),
  :Name( "Mean(v16)" ),
  :Name( "Mean(v18)" ),
  :Name( "Mean(v19)" ),
  :Name( "Mean(v20)" ),
  :Name( "Mean(v21)" ),
  :Name( "Mean(v22)" ),
  :Name( "Mean(v23)" ),
  :Name( "Mean(v24)" ),
  :Name( "Mean(v25)" ),
  :Name( "Mean(v26)" ),
  :Name( "Mean(v27)" )
          ),invisible
Column( dt1, 2 ) << set name( "Mean" );
//Set label
lst = {Eval( Column( dt1, 1 ) << get name ) || "                    " || Eval( Column( dt1, 2 ) << get name )};
//Populate list, conditional number of tabs between columns.
For Each Row(
  Insert Into(
                    lst,
                    Char( :Label[] ) || "          " || If( Length( :Label[] ) < 9, "          ", "" ) || Char( :Mean )
nw = New Window( "\!"Table box\!"", lb = List Box( Eval List( lst ), nlines(20) ) );
And of course one nice little by-product of that would be the built-in ability to select one or more rows of the resulting summary table - which actually would be remarkably useful to me in the present context.  I can infer however that there probably isn't an easier way of doing it, so for the time being I'll probably just put up with the indeterminate length of the table; nevertheless it looks like it could be worthwhile spending some time writing a general function to generate such a display from any given table box with any specified number of rows and columns.  It may however have to wait until the Christmas break!
Thank you - that's very helpful.
David
