uday_guntupalli
Level VIII
Efficient Construction of XML and JSON
All,
   Looking for guidance on encoding data into XML as well as JSON from JMP (just to narrow the scope - associative arrays). The following discussion had some relevant to JSON construction, but i was running into some errors with the function posted and also did not see if a solution was acheived. This can be acheived reasonably by using either R ( toJSON function) or Python. Wondering how this can be done in JSL.
    https://community.jmp.com/t5/Discussions/Define-JSON-structure-for-data-exchange-which-supports-tabl...
Best
Uday
Re: Efficient Construction of XML and JSON
Not all is lost! :)
As JSON Expr was introduced in 13.0 so you have it. You won't have Parse JSON and JSON boolean constants, though, and Associative Array construction is not as streamlined as in the example above. I just tested the following in 13.1:
aa = [
"a" => 1,
"b" => "B",
"c" => 1
aa["d"] = ["d1" => 1, "d2" => 2];
aa["e"] = {1, 2};
// JSL to JSON string
json = As JSON Expr( aa );
Show(json);
The result is:
json = "{\!"a\!":1,\!"b\!":\!"B\!",\!"c\!":1,\!"d\!":{\!"d1\!":1,\!"d2\!":2},\!"e\!":[1,2]}
How about using As JSON Expr()? You can give it your associative array and it should take care of the rest.
aa = [
	"a" => 1,
	"b" => "B",
	"c" => true,
	"d" => [ "d1" => 1, "d2" => 2],
	"e" => { 1, 2, 3}
Show(json);
// JSON string back to JSL
aa2 = Parse JSON (json);
// check if they match
Show(char(aa) == char(aa2));
The result should be (tested in 14.0):
json = "{\!"a\!":1,\!"b\!":\!"B\!",\!"c\!":\!"true\!",\!"d\!":{\!"d1\!":1,\!"d2\!":2},\!"e\!":[1,2,3]}";
Char(aa) == Char(aa2) = 1;
uday_guntupalli
Level VIII
@nascif_jmp,
        I only have JMP 13.1.0 at this point. But will make a note. Thank you.
Best
Uday
Not all is lost! :)
aa = [
"a" => 1,
"b" => "B",
"c" => 1
aa["e"] = {1, 2};
Show(json);
The result is:
BioData41
When I run this in JMP 13.0, I get the following output in the log window:
json = "{\!"unsupported\!":\!"\!"}
Any idea what might be wrong?
aa = [
"a" => 1,
"b" => "B",
"c" => 1
aa["e"] = {1, 2};
json = As JSON Expr(aa);
Show(json);
uday_guntupalli
Level VIII
@BioData41
        I tested your code in JMP 14 and JMP 13.1.0 and it worked fine. Sorry I don't have access to JMP 13.0
Best
Uday
