BookmarkSubscribeRSS Feed
Effect of local PC settings on parsing text
An interesting little problem arose recently in the context of a script that is required to run in several locations around the world. Solving the immediate problem is straightforward enough, but I wondered whether there's a more general solution.
The problem was caused by some of the PCs on which the script was being run having different settings for their number formats. In this instance the decimal point in one location had been set to "·" (ASCII code 250) as opposed to the usual one on a UK keyboard ("."). In Windows 7 this can be changed in Control Panel | Clock Language and Region | Change the Date, Time or Number Format | Additional Settings | Decimal Symbol.
The effect was that any line involving an eval(parse(...)) construction crashed the program, as this trivial example shows:
A = 123.456; B = 1.0;
TextToParse = "C = " || char(A+B);
eval(parse(TextToParse));
Unexpected "·456". Perhaps there is a missing ";" or ",".
Line 1 Column 8: C = 124►·456
The remaining text that was ignored was
·456
124
To sort this out obviously all I need to do is write a small function of my own to replace the "char" function, looking for any unexpected characters in a text field which I know should be a number, and replacing them with the normal decimal point. However, I'd like to know if there's a universal fixit to interpret correctly something more complicated like a user with Arabic or Cyrillic numerals, or negative numbers being displayed in parenthesis. Does anybody know if there is?
(Incidentally, I've tried changing other settings within the "Additional Settings" screen without encountering any difficulties: the decimal point is the only one I've found that causes trouble so far, but I imagine there could potentially be others.)
Here's the sort of function I had in mind, though I imagine it can be shortened:
style="font-size: 9pt; font-family: "Courier New"; color: black;">textfromnumber
style="font-size: 9pt; font-family: "Courier New"; color: navy;">=
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">function
style="font-size: 9pt; font-family: "Courier New"; color: black;">({
style="font-size: 9pt; font-family: "Courier New"; color: black;">x}
style="font-size: 9pt; font-family: "Courier New"; color: navy;">,
{default
local}
style="">
charx
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">char
style="font-size: 9pt; font-family: "Courier New"; color: black;">x)
style="font-size: 9pt; font-family: "Courier New"; color: navy;">;
style="">
validchars
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"-0123456789."
style="">
newcharx
style="font-size: 9pt; font-family: "Courier New"; color: purple;">""
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">for
style="font-size: 9pt; font-family: "Courier New"; color: black;">i
style="font-size: 9pt; font-family: "Courier New"; color: teal;">1
i
style="font-size: 9pt; font-family: "Courier New"; color: navy;"><=
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">length
style="font-size: 9pt; font-family: "Courier New"; color: black;">charx)
i
style="font-size: 9pt; font-family: "Courier New"; color: navy;">++,
style="">
testchar
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">substr
i
style="font-size: 9pt; font-family: "Courier New"; color: black;">)
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">if
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">contains
style="font-size: 9pt; font-family: "Courier New"; color: black;">validchars
testchar)
testchar
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"."
style="">
newcharx
newcharx
style="font-size: 9pt; font-family: "Courier New"; color: navy;">||
testchar
style="">
style="">
newcharx
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">No
style="font-size: 9pt; font-family: "Courier New"; color: teal;">123.456
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">show
style="font-size: 9pt; font-family: "Courier New"; color: black;">No))
style="font-size: 9pt; font-family: "Courier New"; color: black;">textfromnumber(No))
style="font-size: 9pt; font-family: "Courier New"; color: silver;">
style="font-size: 9pt; font-family: "Courier New"; color: black;">Char(::No):"123·456"
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: black;">"123.456"
ms
Jun 23, 2011
I get exactly the same error in JMP (8 & 9) for Macintosh with my system set to use "," as decimal separator.
JSL works only with decimal numbers entered with "." but the format of the Char() output for some reason adapts to the system settings. And Parse() has then of course no clue if the comma represents a decimal point or an JSL argument separator.
I have not found a general solution. But here's another, slightly shorter, custom Char() function.
Char(A) = "123,456";
"123.456";
