BookmarkSubscribe
smushieduckface
Editing a table in a script
I want to write a JMP script which gives the user the option to edit a data table that is already embedded in the script (using the New Table function) and then once the user is finished editing, they can press a button saying done and the script continues running automatically. The changes do not need to be saved, the script just uses it as the current data table.
Is this possible to do? I tried doing this using a dialog box but you cannot edit anything when a dialog box is open.
Any ideas?
Thanks!
