Looking for some help here, I can't get the display box to work correctly as it kept changing back to a blank window when "Option 1" is re-selected (some photos for reference).
Really appreciate the help!
names default to here(1);
Buttons = {"Button 1", "Button 2", "Button3"};
Boxes = {"Box 1", "Box 2", "Box 3"};
LB_Input_1 = lineupbox(ncol(2),spacing(5));
for(i=1,i<=nitems(Buttons),i++,
label1 = char(Buttons[i]);
bblabel1 = "clb_" || char(i);
eval(parse(evalinsert("\[LB_Input_1 << append(buttonbox("^label1^", ^bblabel1^ << append(clb2 << get selected)))]\")));
eval(parse(evalinsert("\[LB_Input_1 << append(^bblabel1^ = col list box("Numeric",minitems(1),maxitems(1),nlines(1)))]\")));
for(i=1,i<=nitems(Boxes),i++,
label1 = char(Boxes[i]);
neblabel1 = "neb_"||char(i);
eval(parse(evalinsert("\[LB_input_1 << append(Text box("^label1^"))]\")));
eval(parse(evalinsert("\[LB_input_1 << append(^neblabel1^ = Number edit box())]\")));
HB1 = hlistbox(
clb2 = filter col selector(dt1,all),
LB_input_1
LB_Input_2 = lineupbox(ncol(2),spacing(5));
for(i=1,i<=nitems(Buttons)-1,i++,
eval(parse(evalinsert("\[LB_Input_2 << append(buttonbox("^label1^", ^bblabel1^ << append(clb2 << get selected)))]\")));
eval(parse(evalinsert("\[LB_Input_2 << append(^bblabel1^ = col list box("Numeric",minitems(1),maxitems(1),nlines(1)))]\")));
for(i=1,i<=nitems(Boxes)-1,i++,
eval(parse(evalinsert("\[LB_input_2 << append(Text box("^label1^"))]\")));
eval(parse(evalinsert("\[LB_input_2 << append(^neblabel1^ = Number edit box())]\")));
HB2 = hlistbox(
LB_input_2
dt1 = current data table();
new window("Test",
vb1 = vlistbox(Text box(""),
Panel Box("Selection Option",H list box(text box("Select: "),
combo1 = combobox({"Option 1","Option 2"},
<< set function(function({this,index},
match(index,
1,
vb1 << append (try(view << delete);
view = HB1;
2,
view = HB2;
text box (""),
view = HB1;
