Adbash
Dot Distribution Map for South Korea
Does anyone know where I can obtain South Korea shapefile that is compatible with jmp.
I want to do a dot distribution of some random locations with just addresses (without longitute and latitude) on South Korea map.
I will sincerely be grateful if anyone here can assist me on how to do this.
Thanks.
Re: Dot Distribution Map for South Korea
Have you seen Justin's add-in?
Adbash
Thank you, Mark Baily, for your prompt response sir.
I tried the method in Justin's add-in as suggested but I am not getting what I actually need.
The link below shows exactly what I want to do, but for South Korea not USA as shown in the first figure in the link.
https://community.jmp.com/t5/JMP-Blog/A-JMP-add-in-to-geocode-your-geographic-data/bc-p/78321#M3428
