BookmarkSubscribeRSS Feed
mwechtal
Community Trekker
Jan 19, 2012
Distribution Platform - Set Spec Limits for KSigma
I want to run the Distribution Platform with the Set Spec Limits for KSigma message on many datasets. I've found the section in the Scripting Guide, and the information in the Scripting Index that apply. However, I have a situation where there is only an upper limit. When I set Sided = 1, it gives me only the lower limit. Is there a way to force only an upper limit?
Example:
Distribution(
  Continuous Distribution(
    Column( :Y ),
    Outlier Box Plot( 0 ),
    Fit Distribution(
          Weibull with threshold(
        Set Spec Limits for KSigma( 4 , Sided = 1)
laural_jmp
Apr 7, 2014
Solution
Re: Distribution Platform - Set Spec Limits for KSigma
It looks like the scripting index is incorrect.  Try using the following to get a USL only:
Example:
Distribution(
    Column( :Y ),
    Fit Distribution(
        Set Spec Limits for KSigma( 4 , Sided = 2)
The scripting index should say, "The optional sided argument is 1 for one-sided, LSL only, or 2 for one-sided, USL only."  There is no needed to have the optional "sided" argument for 2-sided spec limits.
laural_jmp
Apr 7, 2014
Solution
Example:
Distribution(
    Column( :Y ),
    Fit Distribution(
mwechtal
Community Trekker
Jan 19, 2012
Laural,
Yes! That worked. Thanks so much!
