Distance Calculation using Latitude and Longitude
Does anyone has idea how to calculate the distance between states in the US using either zip code or latitude and longitude?
Jenkins Macedo
13 REPLIES 13
mjvincent87
Re: Distance Calculation using Latitude and Longitude
Another thank you to ron_horne!  Just a couple questions:
Just want to confirm the output is statute miles, correct?
Also, do you have a script for bearing between two coordinates?
Amazing collection of formulas:
http://www.movable-type.co.uk/scripts/latlong.html
ron_horne
Hi @mjvincent87
have a look at this script and let me know if it is the direction you are thinking of:
Clear Globals();
// open data file (dots) - this includes the observation we want to update
dt = Open( "$SAMPLE_DATA/Hurricanes.jmp" );
// introduce the column with the distance to be updated in the dots table
dots << New column ( "Distance", Numeric );
Dots << New Column("Bearing", Numeric, "Continuous", Format("Latitude DMS", "PUNSGN", 15, 0));
// extract the longitude and the latitude values from the table - as radians
x = (Column( dots, "Longitude" ) << getValues) * Pi() / 180 ;
y = (Column( dots, "Latitude" ) << getValues) * Pi() / 180 ;
// declare the distance calculation function in KM based on world radius of 6371 KM.
// For statute miles multiply final distance d by 0.621371.
// For nautical miles multiply final distance d by 0.539957
haversine = Function( {long1, lat1, long2, lat2, R = 6371.009},
	{Default Local},
	a = Sin( (lat1 - lat2) / 2 ) ^ 2 + Cos( lat1 ) * Cos( lat2 ) * Sin( (long1 - long2) / 2 ) ^ 2;
	c = 2 * ATan( a ^ 0.5, (1 - a) ^ 0.5 );
	d = R * c //  *0.621371 For statute miles;
wait (0.01);
// run the function along the rows of the table
For( i = 1, i <= N Row( dots ) - 1, i++,
	dots:distance[i] = haversine( x[i], y[i], x[i + 1], y[i + 1] )
// Declare the Bearing calculation function
Bearing = function ({long1, lat1, long2, lat2 },
	{Default Local},
	abc = sin (long2 - long1) * cos (lat2);
	def = cos (lat1) * sin (lat2) - sin (lat1) *cos (lat2) * cos (long2 - long1) ;
	brng = mod (( (atan ( abc, def )) * 180 / pi() ) + 360 , 360)  ;
wait (0.01);
// run the Bearing function along the rows of the table
	dots:Bearing[i] = Bearing( x[i], y[i], x[i + 1], y[i + 1] )
Best,
ron
ron_horne
Hi @mjvincent87 and @jenkins_macedo
another way of doing this is with column formula in a data table. try the following script
Clear Globals();
// Open data file
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
// add column for distance
dt << New Column( "latrad", formula( :Latitude * (Pi() / 180) ) );
dt << New Column( "longrad", formula( :Longitude * (Pi() / 180) ) );
dt << New Column( "Distance", Numeric,
	formula(
		6371.00 * 2 * ATan(
			(Sin( (:latrad - Lag( :latrad, -1 )) / 2 ) ^ 2 + Cos( :latrad ) * Cos( Lag( :latrad, -1 ) ) * Sin( (:longrad - Lag( :longrad, -1 )) / 2 )
			 ^ 2) ^ 0.5,
			(1 - (Sin( (:latrad - Lag( :latrad, -1 )) / 2 ) ^ 2 + Cos( :latrad ) * Cos( Lag( :latrad, -1 ) ) * Sin(
			) ^ 2)) ^ 0.5
dt << New Column( "Bearing", Numeric, "Continuous", Format( "Latitude DMS", "PUNSGN", 15, 0 ),
	formula(
		brng = Mod(
			((ATan(
				Sin( Lag( :longrad, -1 ) - :longrad ) * Cos( Lag( :latrad, -1 ) ),
				Cos( :latrad ) * Sin( Lag( :latrad, -1 ) ) - Sin( :latrad ) * Cos( Lag( :latrad, -1 ) ) * Cos( Lag( :longrad, -1 ) - :longrad )
			)) * 180 / Pi()) + 360,
			360
