BookmarkSubscribeRSS Feed
ncsu_ee
Oct 4, 2011
Displaying Grand Median in Variability Plot
I am trying to find a way to display the value associated with the Grand Median to the right of my plot, similar to the way Grand Mean does. Any ideas how to do this?
Thanks,
-Z
carole
Jun 23, 2011
I don'y know if it's a solution for you but i'm used to do this :
- Click right in the variability Chart (the frame box) and then click Customize
- Add a new script containing :
valmed = Col Quantile( :Name( "YOURCOLNAME" ),0.5 );
Text( Right Justified, {2, valmed}, "GdMed="||Char( valmed ) );
The value will be displayed in the frame box, you can manually re-size it to adapt and see all correctly.
In my case i had only 2 groups, that's why the first number of {2, valmed} is 2. You can adapt it to your case to keep the value on the right.
ncsu_ee
Oct 4, 2011
Thank you for your help Carole.
I managed to get this code to execute, but it wasnt exactly what I was looking for. The code you posted above does display the median, but I couldn't get the text to display outside the chart area. I was looking for something like what JMP does when you enable the Grand Mean, which shows the numeric value to the right of the chart.
I managed to find the median of my data and added the text box manually after the chart was generated. Not the most graceful, but it works.
-Z
