hogi
Level XIII
Display Tree Indexing - how does it work?
Helpful Information from the community:
Subscripting:
Display Boxes with Subscripts
Xpath:
xPath coding help /  (Xpath "family" tree)
All OutlineBoxes with title condition By XPath (@helpKey)
All in One:
I-Can-See-It-How-Do-I-Get-It   (Discovery Summit 2024, @Mark_Bailey , @tonya_mauldin)
hogi
Level XIII
Re: Display Tree Indexing - how does it work?
There are some cases where DisplayBox Subscripting like
current report()["Summary Statistics"]
gives surprising results. Which information is accessed via the string?
In this example,
JMP doesn't find the first Local Data Filter -- maybe: because it's title is changed to "LDF"?
JMP finds the first summary statistics - although it's title is changed to "statistics".
I first noticed this behavior with a Graph Builder outline box. JMP finds it even when the title is changed.
At the time, I thought JMP was looking for the @helpKey - and that is why it can still find it.
But Summary Statistics (in the example here) doesn't have a helpKey.
So JMP finds something that is not visible to the user.
And it won't find it if it's a local data filter...
New Window( "test",
	V Splitter Box(
		Distribution(
			Continuous Distribution(
				Column( :height )
			Local Data Filter(Title( "LDF" )  ),
				Local Data Filter,
		Dispatch( {}, "Distributions", OutlineBox, {Set Title( "hello" )} ),
				Dispatch( {"height"}, "Summary Statistics", OutlineBox,
			{Set Title( "statistics" )}
		Distribution(
				Column( :height )
			Local Data Filter(  )
current report()["Local Data Filter"] << select();
//current report()["Distributions"] << select();
current report()["Summary Statistics"] << select();
hogi
Level XIII
There are different ways how the titles of the OutlineBoxes are changes, so let's try:
New Window( "test",
	V Splitter Box(
		Distribution(
				Column( :height )
			Local Data Filter( ),
				Local Data Filter,
		Dispatch( {}, "Local Data Filter", OutlineBox, {Set Title( "LDF" )} )
		Distribution(
				Column( :height )
and indeed:
If the title is changed by sending a dispatch message to the report layer, the report layer will also find the display box via the original title.
hogi
Level XIII
Now, let's change the environment:
It's great, JMP doesn't get fooled by the titles, it still finds the display boxes via the english names :)
Unfortunately, a German JSL developer will see this information in the "Properties" menu:
and it's quite likely that an English speaking colleague will see:
hogi
Level XIII
Note to myself:
  • use English names for Dispaly Box Substripting
  • use Dispatch(...) to change the title of Outline Boxes, not  Local Data Filter(Title( "LDF" ) )
