BookmarkSubscribeRSS Feed
Display Bar chart numbers on top of each Bar
I want to know if there is a way to display the label for each of the bars on the JMP bar chart?
Is there a setting to trigger this?
Thanks in advance.
chungwei
Jun 23, 2011
Re: Display Bar chart numbers on top of each Bar
I think an option from the Label Options (click the red triangle or right-click in the chart area) will do what you want.
This video shows how to add the labels:
http://www.youtube.com/watch?v=GP7FRFB2goQ
Hi guys,
just to check - can we also add labels in graph builder too?
the video did show that it worked for regular bar/other visuals but i couldnt find the same option in the interactive graph builder.
any suggestions is appreciated, thanks
Currently it's not possible to add the labels in Graph Builder
thanks for advice - in that case i'll just use the regular charts if i must have labels.
