nocaltim
Disable "Missing Rows" annotation in One-Way plots
Can anyone suggest a way to disable the automatic (and mandatory?) annotation that appears on every One-Way plot stating the number of "Missing Rows"??  I understand why it is there -- it tells me how rows of data were omitted in plotting my data, but most of the time I don't need this information and it just clutters the plot and raises questions from people when presenting this real-time.  (Please refer to image below for example "Missing Rows" annotation).
ian_jmp
Re: Disable "Missing Rows" annotation in One-Way plots
As you say, the annotation is there for very good reasons.
You can always remove parts of any report via JSL with this kind of approach:
// Make some missing values
vals = Column(dt, "height") << getValues;
vals[J(10, 1, RandomInteger(1, NRows(vals)))] = .;
Column(dt, "height") << setValues(vals);
// Use Oneway
ow = dt << Oneway( Y( :height ), X( :sex ) );
// Delete the required part of the display tree
Wait(3);
owRep = ow << report;
// Uncomment the line below to see the display boxes that comprise the current report
// owRep << showTreeStructure;
owRep[LineupBox(1)] << delete;
More generally, you can manipulate the display tree of a report by rearranging or adding things.
Article Labels
