BookmarkSubscribeRSS Feed
stephen_pearson
Oct 6, 2014
Dirichlet distributions in JMP (for Bayes prior)
I am trying some Bayesian bootstrapping and would like to do it in JMP Pro. One of the prior distibutions I would like to use is Dirichlet. I was thinking of using the column data type Expression to hold vectors of the weights and using the Compress to Label Addin to index the unique values in the column so I know which row/column of the vector contains the correct weight to apply.
I can generate Dirichlet vectors using the R connector (below) but would like to do it in a formula column so I can take advantage of the Bootstrap feature in Pro. Any suggestions?
R Init();
//input list, outputlist, Rcode
rc = R Execute(
{nSamples,pollResult},
{x},
	library (DirichletReg)
	x <- rdirichlet(nSamples, c(728,584,138))"
Wait( 3 );
//get dataframe from R
resultMatrix = R Get(x);
//close connection
R Term();
//export results
dt = As Table( resultMatrix );
Milo
Nov 10, 2016
Solution
Re: Dirichlet distributions in JMP (for Bayes prior)
Hi Stephen,
You can paste the code below into a column formula, and it should sample from a Dirichlet. I'd recommend that you convince yourself that it's accurate before using it, since I didn't test it. I wrote it based off of https://en.wikipedia.org/wiki/Dirichlet_distribution#Random_number_generation
alpha = [1 2 3 4 5];
gams = Random Gamma(alpha)`;
gams/sum(gams); // values sampled from dirichlet with concentration parameters alpha
Milo
markbailey
Jun 23, 2011
The Dirichlet distribution is not available directly in JMP but you do not need to call R in this case. You can make a column formula in which you use the functions that are available in JMP. See, for example, "What is an intuitive explanation of the Dirichlet distribution?" for more information.
Milo
Nov 10, 2016
Solution
Hi Stephen,
Milo
stephen_pearson
Oct 6, 2014
Combining this infomation with Expand Vector Column Add-in has given me just what I needed. Thanks.
