kayne
Dialog Popup selecting column name
Hi there, I'm trying to come up with a script where the user inputs the column name in the dialog popup and the script
1. subsets the rows with data under the column name and
2. creates a new column that performs some simple formula with the column name that was input.
I do not know how to do it so I hardcoded the column name below. How can I replace the :XX01 such that no mater what the user enters at the dialog pop up it will work. I have columns XX01, XX02, XX03, and so on...
popup = Dialog(
    Title( "Summary Table" ),
    " Enter Softbin   XX:",
    Lineup( 6,
        "Softbin ID ",
        Soft_Bin = editnumber( 01 )
    Button( "Ok" ),
    Button( "Cancel" )
masterdt << select where (Is Missing(:XX01));
masterdt << Invert Row Selection;
sbdt = masterdt << Subset(( Selected Rows ), Output Table Name("Selected Softbin Data"));
sbdt << New Column( "Bin%", Numeric, Continuous, Format("Percent",12,2), Formula( :XX01 / :LOT_SORTED_DIES ) );
pmroz
Re: Dialog Popup selecting column name
This will do what you want.  I converted your code to use new window instead of dialog.  Had to do a parse(eval()) for the column formula.
masterdt = New Table( "Master DT", Add Rows( 5 ),
      New Column( "XX01", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [1, 2, ., 3, 4] )
      New Column( "XX02", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [., 1, 2, ., .] )
      New Column( "XX03", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [., ., 1, 2, 3] )
popup = New Window( "Summary Table", <<modal(),
      Text Box( "Enter Softbin XX:"),
      H List Box(
            Text Box( "Softbin ID:  " ),
            Soft_Bin = Number Edit Box( 01 ),
      hlistbox(
            Button Box( "Ok",
                  ok_flag = 1;
                  ncol = soft_bin << get;
                  if (ncol < 9,
                        selected_col = "XX0" || char(ncol);
                        selected_col = "XX" || char(ncol);
            Button Box( "Cancel", ok_flag = 0 ),
If( ok_flag,
      missing_rows = masterdt << get rows where( !Is Missing( as Column( masterdt, selected_col ) ) );
      If( N Rows( missing_rows ) > 0,
            masterdt << select rows( missing_rows );
            sbdt = masterdt << Subset( (Selected Rows), Output Table Name( "Selected Softbin Data" ) );
            formula_expr = Eval Insert(
                  "\[sbdt << New Column( "Bin%", Numeric, Continuous, Format( "Percent", 12, 2 ), Formula( :^selected_col^ / :LOT_SORTED_DIES ) )]\"
            Parse( Eval( formula_expr ) );
pmroz
      H List Box(
      hlistbox(
            Button Box( "Ok",
                  ok_flag = 1;
                  if (ncol < 9,
If( ok_flag,
kayne
Thanks PMroz, the window is indeed useful. Everything is smooth except for the New Column portion.
I'm not sure what I did wrongly but the eval insert sentence is still not working although the expression in the log looks fine to me :\
      New Column( "LOT_SORTED_DIES", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [10, 10, 10, 20, 30] )
        H List Box(
      hlistbox(
            Button Box( "Ok",
                  ok_flag = 1;
                  if (ncol < 9,
If( ok_flag,
ms
Super User (Alumni) ms
I think the expression will work if parsed before evaluated:
Eval( Parse( formula_expr ) );
kayne
Thanks MS! It works now =)
pmroz
Right you are MS.  Thanks for the correction.
