News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
robot
Determine if a Display Tree Branch Exists
I would like to script a JSL command to close a branch of a display tree.  My problem is, depending on circumstances, sometimes this branch will exist, and other times it will not.  If the command to close the branch is sent, and that branch does not exist, the user gets an error.  I imagine one possible solution is to write an IF statement to determine if the branch exists; if yes, close that branch; if no, ignore the that command and move on.  Does anyone have any recommendations?  I am using JMP9.
// My fantasy code...
If(
     Exists( report[Outline Box( 6 )]) == 1, report[Outline Box( 6 )] << Close( 1 );
ms
Super User ms
Re: Determine if a Display Tree Branch Exists
Try Try! If the expression returns an error it is ignored and the script execution moves on as if nothing has happened.
Try(report[Outline Box( 6 )] << Close( 1 ))
ms
Super User ms
robot
Works great!  Thanks!
