sarahmingels
Determine confidence interval for ICC
I'm currently using the EMP platform from jmp to determine ICC's for: 30 repeated measures, 1 rater, 10 participants.
Is is possible to deduct CI's for the ICC's?
Thank you,
Sarah
Re: Determine confidence interval for ICC
I cannot find a way to produce the interval in JMP. It is not available as hidden columns in the report or an option with platform command. I thought of bootstrapping the interval using JMP Pro but this option is not available in in the EMP platform.
I do not happen to know a formula for the interval.
You might add this feature to the Wish List area in the JMP Community or search for it and vote for it if it is already there.
sarahmingels
Dear Mark,
Thank you for the quick response. Do you know an other way that I could use? For me it seems always interesting to provide the confidence interval.
I will add the question to the wish list
Kind regards
Sarah
No, as I said, I don't know of a way. But someone else here might know.
