Mi
Mi
Dendogram
Good morning,
I often have the problem that the ID is not shown in the dendogram during cluster analysis.
What should I change, or what can I do ?
Thanks for the help!
Thierry_S
Re: Dendogram
Hi Mi,
The issue is that you have a quite large table (> 1900 rows). One option is to increase the size of the Color Map to > 8,000 pixels (right click on the map > Frame Size).
Another option would be to Hide and Exclude the rows that are not informative (Select Cluster with low signal > Right Click > Row Exclude)
Best regards,
TS
Thierry R. Sornasse
Thierry_S
Re: Dendogram
Hi Mi,
Best regards,
TS
Thierry R. Sornasse
Mi
Mi
Re: Dendogram
Hi TS,
Thanks for your message.
True in this file are many lines.
But I want all of them in it...
The size of the dendegram would become too large for a representation.
 Then I'll have to do it without the label.
Have a nice day!
