BookmarkSubscribeRSS Feed
daniel_harding
Deleting two rows and repeating the rest of the data
I have a new column in my data table and using JSL,  I need to remove the first two rows of the column, move the remaining data up to the top of the column, and then repeat those values until the final row.  Attached with this question is what it looks like right now.
Thanks for any suggestions or help!
wiebepo
Re: Deleting two rows and repeating the rest of the data
This should work for the example. Replace 'Column 1' with the column name of interest.
data_raw=currentdatatable();
data_table=data_raw<<subset(rows(
          data_raw<<getrowswhere(
               !ismissing(:Column 1)
               &row()!=1
               &row()!=2
     invisible
data_rows=column(data_table,"Column 1")<<getasmatrix();
close(data_table,nosave);
For(i=1;k=1,i<=nrows(data_raw),i++;k++,
     column(data_raw,"Column 1")=data_rows;
     If(k==nrows(data_rows),k=0);
wiebepo
               &row()!=1
               &row()!=2
     invisible
daniel_harding
That works perfectly. Thank you so much!
