asvp
Deleting rows using JSL scripts
How can we delete rows from a data table (using JMP script) when some columns in this data table satisfy a particular criteria?
Using Delete Rows is not working for me in my script.
Thanks
ms
Super User (Alumni) ms
Re: Deleting rows using JSL scripts
Here is one way to do it.
dt = Current Data Table();
For Each Row( Row State() = Selected State( criteriacolumn[] == criteria ) );
dt << delete rows();
pmroz
Here's another way. I don't know if it's any faster.
dt << select where(:N < min_case_value);
dt << delete rows;
ms
asvp
Thanks MS, it works.
pmroz
dt << delete rows;
mpb
mpb
> faster.
Well I made a table with 6 columns and 100,000 rows and the For solution took about 1 second and the direct select took "0" seconds.
When I increased the number of rows to 1,000,000 then the For solution took 11 or 12 seconds and the direct select took 3 seconds.
So on my pc running winXP using this particular table the direct select is about 4 times faster but you would need a really large table to notice the difference.
Michael
ms
Thanks!
Fast is good. The direct method has also the advantage that easier to read (and remember).
The loop method still is useful when you need to set other or combined row states.
