Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
I am trying to reduce the number of rows. I need a function where if Column 3 have any empty cell , it will delete the whole row. here is a picture of the table in this case Column 3 name is (Row 4)
