BookmarkSubscribeRSS Feed
volf
Staff (Retired)
Delete focused row in String Col Edit Box
I should implement a function to delete focused row in String Col Edit Box through JSL.
This function is difficult for me because the column header is combobox which changes values of the string col edit box. Also, I can’t use
Table Box in this case. please find attached file.
If I get number of focused row in String Col Edit Box, I could delete the row.
I am using JMP 10 in windows 7 environments.
Thank you in advance.
Regards,
Sung-soo.
