BookmarkSubscribeRSS Feed
geof2
Sep 27, 2013
Delete columns in different tables
I try to delete columns on multiple tables.
In the second  For loop I have an invalid argument.  but works on the first table only...
Thanks
geof
Open("D:\A.csv");
Open("D:\B.csv");
Open("D:\C.csv");
t_count = N Table();
For(i = 1, i <= t_count, i++,
     dt=Data Table(i);
     N = N Col(dt);
     ColumnstoKeep={"AA","BB"};
     ColumnstoTrash = {};
     For( j = 1, j <= N, j++,
          colname = Column( j ) << getname();            / Debugger said invali argument  !?/
          If( Contains( ColumnstoKeep, colname ) < 1,
               Insert Into( ColumnstoTrash, colname )
     dt << delete columns( ColumnstoTrash );
michaelhaslam_p
Sep 15, 2013
Solution
Re: Delete columns in different tables
geof2,
Your use of the column() function lacks a reference to the specific datatable you need, so you are operating on the current table only.  This is the C.csv table, that last one you opened.  Use Column( dt, j ).  So, for your second loop, use:
          colname = Column( dt, j ) << getname();
I also recommend that you use something other than j for your index.  j is a reserved function in JMP.
Michael
michaelhaslam_p
Sep 15, 2013
Solution
geof2,
Michael
geof2
Sep 27, 2013
Thanks very much :-)
