BookmarkSubscribeRSS Feed
antoinesofradir
Apr 26, 2013
Delete Double Row in a data table
I have lots of Double row in my data table and i would like to clean it.
I only want distinct value in my data table.
Is there a function to do it ?
Thanks for your help !
ms
Jun 23, 2011
Solution
Re: Delete Double Row in a data table
The problem is that set name is sent to dt (the original table) and not to the summary table (dt = current data table() is only executed once, i.e. the variable dt is locked to that table unless dt is redefined).
Try this:
dt_sum = dt << summary( group( dt << get column names ), Link to original data table( 0 ) );
dt_sum << Set Name( "New table" );
6 REPLIES 6
ms
Jun 23, 2011
I think the easiest way get rid of duplicates is to use Summary (in tables menu) and add all columns to the Group field. You will get a new table that needs to be saved and one extra column N Rows that can be deleted. Row state columns and column formulas will be retained.
A script example:
dt = Current Data Table();
antoinesofradir
Apr 26, 2013
Thank you for your answer, it works !
I tried to name the new table but it doesn't work :
dt<< Set Name("New table");
What is the problem ? Thank you for your help !
ms
Jun 23, 2011
Solution
Try this:
antoinesofradir
Apr 26, 2013
Thank you very much !
saitcopuroglu
Sep 29, 2014
Dear MS,
Related to the subject, I can set names of summary tables, subset tables but somehow I can't do it:
After creating a tabulate and making a table of it, I am unable to add a name to the table created. Wherever I put "Set Name" command it does not work:
<<Tabulate(
    Change Item Label(
        Grouping Columns( :Contract( "All" ), "All" ),
        Grouping Columns( :Room Type( "All" ), "All" ),
        Grouping Columns( :month( "All" ), "All" )
    Remove Column Label( Grouping Columns( :Room Type, :month, :Resort ) ),
    Uniform plot scale( 0 ),
    Set Format(
        Sum( :NetRevenue( 22, 0 ), :Name( "FChNight/AdNight" )(18, 0), :ADB( 19, 0 ) ),
        Column %( :Name( "FChNight/AdNight" )(16, 1), :ADB( 17, 0 ), :RoomNight( 21, 0 ) ),
        Mean( :NetRevenue( 20, 2 ), :Name( "FChNight/AdNight" )(16, 1), :Disc%( 16, 0 ), :ADB( 17, 0 ), :RoomNight( 21, 0 ) ),
        Row %( :Name( "FChNight/AdNight" )(16, 0), :RoomNight( 21, 0 ) ),
        Name( "% of Total" )(9, 2)
    Include missing for grouping columns( 1 ),
    Add Table(
        Column Table( Grouping Columns( :Resort ), Analysis Columns( :NetRevenue ), Statistics( Sum, Column % ) ),
        Column Table( Analysis Columns( :AvgRN ), Statistics( Mean ) ),
        Column Table( Analysis Columns( :DoubleOcc ), Statistics( Mean ) ),
        Column Table( Analysis Columns( :Name( "FChNight/AdNight" ) ), Statistics( Mean ) ),
        Column Table( Grouping Columns( :EB ), Add Aggregate Statistics( :EB ), Statistics( Name( "% of Total" ) ) ),
        Column Table( Analysis Columns( :Disc% ), Grouping Columns( :month ), Add Aggregate Statistics( :month ), Statistics( Mean ) ),
        Column Table( Analysis Columns( :ADB ), Grouping Columns( :month ), Add Aggregate Statistics( :month ), Statistics( Mean ) ),
        Column Table( Analysis Columns( :RoomNight ), Grouping Columns( :month ), Statistics( Row % ) ),
        Column Table( Analysis Columns( :RoomNight ), Grouping Columns( :Room Type ), Statistics( Row % ) ),
        Row Table( Grouping Columns( :Contract ), Add Aggregate Statistics( :Contract ) )
    )  << Make Into Data Table,
ms
Jun 23, 2011
Try this sequence of commands:
dt = Open("$SAMPLE_DATA/Car Poll.jmp");
tab = dt << Tabulate(
    Show Control Panel(0),
    Add Table(
        Column Table(Grouping Columns(:sex, :marital status)),
        Row Table(Grouping Columns(:country, :size))
dt_sum = tab << Make Into Data Table;
dt_sum << Set Name("New table");
