Gadsdon
Degrees of Freedom and control charts
Hi Is there any clever way that I can see the degrees of freedom when I create a control chart (XbarR, XbarS and Xm/Individual):
Regards Ian
Byron_JMP
Re: Degrees of Freedom and control charts
Ian,
No.
Are you thinking of the span for x-bar and R or S charts?
-B
JMP Systems Engineer, Pharm and BioPharm Sciences
Gadsdon
Hi Byron, this comes from work done by Wheeler (https://www.qualitydigest.com/june97/html/spctool.html). I use the tables in EMP III Evaluating the measurement process & using imperfect data (Chapt 17.6). Its applicable to Xm, XbarR etc
Regards Ian
These values are given in the Measurement Systems Analysis platform under the Quality menu.
