Gadsdon
Degradation (stability) graph, changing colours
Hi I am trying to change the colour of the confidence intervalto more transparent and and a better colour.  I cannot work out how to do this, any help would be appreciated
Thierry_S
Re: Degradation (stability) graph, changing colours
If you are using Graph Builder, right-click on the plot area and choose: Customize. If you use another platform, you may need to experiment with the color preferences for that tool.
Best,
TS
Thierry R. Sornasse
Gadsdon
Hi Thierry, I am using
Analyze/Reliability and Survival/Degradation/Stability test
I previously tried going into Customize but I did not see how to change the confidence interval region
I attach the file where I am having a problem, I sanitized the data
Thanks
peng_liu
I can only think of a workaround, which only partially addresses what you want. That is to change the individual units' color, e.g. make them all blue. Transparency won't change, because the shades stack on top of each other, which adds up the color density.
Please contact [email protected] to add your request.
