I have 7-factors and I am planing to apply a DSD. One of the factor needs to have a skewed center point of 30% (10%-30%-60%) due to experimental limitation instead of 35% required by DSD.
I created a DSD for 7 factors with normal default ranges and I created another DSD but manually changed the center point to desired 30% instead of 35%. Using "Design Evaluation" feature I compared both the design and surprisingly there is not a huge penalty for DSD with Skewed Center point for one of the factors (see attached outputs).
So my question is:
Looking forward for your input on this.
Thank you.
Making such ad hoc changes to a design is what Ron Snee calls, "exercising the boss option." You did exactly the right thing by checking the design diagnostics using the Evaluate Design tool in JMP's DOE menu.
As you can see, your slightly off-center setting has a very minimal effect on the various measures. I would say that there is no practical difference.
The DSD you constructed will do everything that you want as long as your active effects are substantial compared to the error standard deviation.
I guess I would ask have you considered a 10, 30, 50 scenario? The diagnostics that you share with the skewing do not look bad but figured I ask.
Lou V
Well both 10-30-50 scenario and applying Custom Design is possible. I just wanted to discuss with Group about the pros and cons of playing with DSD designs like I did. Design Evaluation shows there is no loss but I also wanted to cross check my approach.
I recently ran into this problem myself. In my case, I wanted to use the current product levels as the centerpoints, then vary the amount of chemicals around the centerpoints. Sometimes the high level was more than twice the total amount compared to the centerpoint level. I didn't want to put in zero for any chemical, so I used asymmetrical levels for some chemicals. Lou helped with the compare Designs to show it didn't make much of a difference.
