chris_dennis
Definitive Screening Design Categorical Factor Levels
I am working on a Definitive screening Design (my first) I set design up with 7 factors one of which was a categorical (equipment type) with two levels.  When reviewing design with team, request was made to skip step for this equipment two set one of the continous factors to 0.
I am reviewing design now and this change really makes the categorical variable into a 3 level item.  I am concerns about issues this may cause with results analysis, and if there are any special steps I should take to modify the design to handle this item?
Any help or suggestions are appriceated.
Thanks, Chris
phil_kay
Re: Definitive Screening Design Catagorical Factor Levels
Okay.
I had a quick look at the consequence of adding the 3rd level to your categorical X1 when X2 = 0. It does have some significant effects on the properties of your design, as you might expect. I would encourage you to have a look for yourself using the Design Evaluation platform.
Also, I am not sure that it really helps with interpretation of the resulting model. Your resulting model would cover possibilities where X1 = L3 (i.e. no machine used) and X2 > 0, which doesn't make a lot of sense.
You could just keep the design as is and not worry that X1 is essentially meaningless when X2 = 0. The term for the interaction of X1 and X2 should be able to capture the fact that there is no difference between levels of X1 when X2=0.
Or you could reframe the problem or rethink factor ranges so that they make more sense.
Or you could go to a Custom Design.
I hope this helps.
Cheers,
Phil
8 REPLIES 8
phil_kay
Hi Chris,
I am not quite sure what you mean. Could you send the design. If necessary you could create an anonymised version jsut with X1... X7 and coded factor levels (-1,0,1).
Regards,
Phil
chris_dennis
Please see attached design example.
[cid:image001.png@01D32B9C.310881D0]
Jeff_Perkinson
Unfortunately, images in email replies don't make it to the Community. @chris_dennis, could you edit your response above to attach the image?
-Jeff
chris_dennis
Example of design shown below. Concern is the Catagorial factor (X1) is the tool used for parameter X2. If X2 is 0 then it does not run on tool for X1 and skips this step. I think this have the effected of making X1 three categories; L1, L2 and None. Is the design still valid under this condition? See attached PDF for design.
phil_kay
That is interesting. So you have a categorical X1 (L1, L2) and a continuous X2 (0, 8000, 16000). And if X2 is 0, then X1 is neither L1 nor L2.
Does it make sense to define X2 as a continous over the range 0 to 16000? After you have run the experiment and modelled the data, will it make sense for the model to make predictions of the response for X2 = 1 or X2 = 500? Would you actually operate in the range 1 to 8000?
Could you change X2 to have a range of 1 to 16000? Or some other range with a lowest setting > 0.
chris_dennis
It is possible for X2 to between 0 and 8000. Logisticly we don't have a setup in that range and wanted to try and get the biggest signal possible. If we see a good response we will look and augmenting with a value between 0 and 8000.
It is possible to do a low value like 1000, but not easy to process.
phil_kay
Okay.
I hope this helps.
Cheers,
Phil
chris_dennis
I change to the Customer Design platform.  Because of the interaction between X1 and X2 I combined these factors into 5 descrete levels.  Thanks for the help.
Chris
