Hello community!
I got a bit stuck while using Classes, so I'm hoping someone could help me out.
A bit of context: I am working on a script which is divided into two: a main script and a functions script, where the latter is then included into the main script. I am trying to work with Classes and Namespaces, to make sure variables are only found when they are supposed to be found. My specific problem comes when trying to use the "On Change" function with a Col List Box.
I made a minimal working example that illustrates my problem. Consider the main code:
Clear log(); Clear Globals(); Clear Symbols();
// Include the class script
If( !Namespace Exists( "mainNamespace" ), New Namespace( "mainNamespace" ) );
mainNamespace:dir = Get Default Directory();
Include(mainNamespace:dir || "classScript.jsl");
// Create an object of the class and try to use the function
testObject = New Object( exampleClass());
testObject:method1();
and then the class script:
If( !Namespace Exists( "classNamespace" ), New Namespace( "classNamespace" ) );
Define Class("exampleClass",
_init_ = Method( {},
this:BC = Open( "$SAMPLE_DATA/Big Class.jmp", Show(1) );
this:window = Empty();
method1 = Method({},
this:window = New Window( "Test Window", clb = Col List Box( all, On Change( Show( clb << Get Items ) ) ) );
);The idea is to have a window open where you can select some columns from a data table, and then get a list with the columns selected. This works fine when I don't use Classes, i.e., if I just write the classes part of the script as "normal" code. The code above manages to open up the Big Class data table, and the window with the Col List Box, but whenever I click on a column, I get an error:
Send Expects Scriptable Object in access or evaluation of 'Send', clb << /*###*/Get Items /*###*/
Is there something I'm doing wrong, or not understanding? Or is it something to do with how "On Change" is programmed? Any help is appreciated!
Actually, the error message I'm getting is:
Name Unresolved: clb in access or evaluation of 'clb', clb/*###*/
sorry about that!
I think the class members have a default local mechanism, whether you want it or not. In
clb is assigned when method1 is running, then forgotten as method1 returns. Much later, when the OnChange method runs, it can't be found. If you want a quick, imperfect fix, make clb more global.
A better, but uglier fix requires embedding clb's value in place of clb.
Define Class( "exampleClass",
// create the instance variables
m_clb = .;
m_window = .;
m_BC = .;
m_BC = Open( "$SAMPLE_DATA/Big Class.jmp" );
m_window = Empty();
method1 = Method( {},
m_clb = Col List Box( all );
// add the on change script after creating the box. The script needs
// to reference the box. Substitute the actual box that m_clb refers
// to for the xxx placeholder name, then evaluate the resulting script
Eval( Substitute(
Expr( m_clb << onChange( Show( xxx << getselected ) ) ),
Expr( xxx ),
m_clb
m_window = New Window( "Test Window", m_clb );
testObject = New Object( exampleClass() );
this probably doesn't do what you expect. There is no equivalent to a C++ this-> and you'll have a hard time inventing it without creating a memory leak. In the example above, it would be even better to embed this rather than clb, but you need to invent a way to get this.
I wrote two blogs about classes, How to use Define Class and Functional programming using JSL objects . I've tried to use classes several times and never been satisfied. One thing that a class does really well is passing by reference, and that may be the best reason to use them. Wrapping a large array in a class instance makes it possible to pass the array to user written functions without making a copy of the array.
And if only the <<OnChange call back received a this parameter, pointing to the box, this would be so much easier.
<< Set Function might be a good option to use instead of << On Change, as it has "this" as function argument. Depending what you are trying to do in the end, I would say there are at least three different options
1. Do what Craige suggest and evaluate the reference to the Col List Box
2. Use << Set Function and then you can reference this (which will refer to the col list box itself). These do have a bit different behaviors but it might affect your application
m_clb = Empty();
m_window = .;
m_BC = .;
m_window = Empty();
m_window = New Window("Test Window",
Datatable(m_BC),
all,
<< Set Function(function({this},
Show(this << get selected)
3. Use window scope ( Scripting Guide > Programming Methods > Advanced Scoping and Namespaces > Scoped Names )
m_window = .;
m_BC = .;
m_window = Empty();
window:m_clb = Col List Box(
Datatable(m_BC),
all,
<< onChange(Show(window:m_clb << Get Selected))
This is an older thread, but I wanted to post one more solution that I think is very handy when dealing with windows inside classes. Similar to Jarmo's solution, you can use the << Set Function message, but use a Method definition. It has approximately the same functionality as a Function with the added bonus of evaluating within the scope of the class, meaning you can reference object variables.
m_clb = Empty();
m_window = .;
m_BC = .;
m_window = Empty();
Datatable(m_BC),
all,
<< Set Function(Method({this},
Show(this << get selected);
Show(m_clb << get selected);
Show(m_window);
Show(m_BC);
testObject:method1();The 'this' variable works the same as Jarmo explained, but you can also reference any other variable from the class. Here 'this' is equivalent to 'm_clb'.
I find using Methods this way is very convenient for creating modular windows with interactive components.
