hockswender
Dataset
There was a paper by Susan Walsh re Nonlinear Fitting at a Discovery Conference 2013. I have been unable to find the datasets from the paper. Any chance they are available? Looks like agood learning opportunity,
susan_walsh1
Staff (Retired)
Re: Dataset
Hello.
Thank you for your interest in the paper. I am able to share three of the four data tables used in the paper. Unfortunately, I do not have permission to share the last data table discussed in the paper. I hope this helps.
Sue
susan_walsh1
Staff (Retired)
Re: Dataset
Hello.
Sue
hockswender
Re: Dataset
Thanks Sue,
They should do just fine. I'm refreshing my use of NLR in JMP so they are just what I needed.
Regards,
Tim
Article Labels
