cbaril
Data transformations
Hello!
I have the following task (see attachment).
I am struggling in particular with step nb 2. Would you know how to tackle this?
Thank you in advance for your support!
Best regards,
Claire
Re: Data transformations
I would most likely use matrix calculations
dt = New Table("Untitled 14",
	Add Rows(10),
	Compress File When Saved(1),
	New Column("e",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([1, 2, 3, 4, 5, 6, 7, 8, 9, 10])
	New Column("t",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([2.2, 3.3, 4.2, 1.2, 5, 7.5, 2.4, 5.6, 8.1, 1.1])
dt << New Column("s", Numeric, Continuous, << Set Each Value(
	As Constant(
		es = :e << get values;
		ts = :t << get values;
		f_row = Min(Loc(ts, 4.2));
		t_idx = Index(f_row, f_row + 2);
		s = Sum(ts[t_idx]);
	If(row() == f_row,
		s,
Raaed
use excel, countA and countif functions
Řaëd ~✍
	Add Rows(10),
	New Column("e",
		Numeric,
		"Continuous",
		Format("Best", 12),
	New Column("t",
		Numeric,
		"Continuous",
		Format("Best", 12),
	As Constant(
		s = Sum(ts[t_idx]);
	If(row() == f_row,
		s,
cbaril
thank you! I will try applying this now to my actual table and see if it works for me.
cbaril
Thank you! My script is now working in my actual datatable (see script below).
I have an additional inquiry! In the same datatable I have 6 data subsets (differentiated by Column X where subsets are differentiated as "a", "b", "c", "d", "e" and "f").
How could I apply this script to all 6 subsets and get the 6 results in the same column?
Best
Claire
__________________________________________
Script:
dt << New Column("sumtempj", Numeric, Continuous, << Set Each Value(
As Constant(
ts = :"Rounded TempJ" << get values;
f_row = Min(Loc(ts,121));
t_idx = Index(f_row, f_row + 359);
sumtempj = Sum(ts[t_idx])-(360*121);
If(row() == f_row,
sumtempj,
