AlexS
Data table number to Data table name with contains and Eval
Hello
The code currently works via data table number (dtlist)but what I need is the Eval to find a table based on contains then update it.
so something like Eval(contains(dtlist,("xx4") then update. if that's even possible?
dtLIst = {};
For( i = 1, i <= N Table(), i++,
	dt = data table(i);
	insert into(dtList, dt );
eval(dtList[4]) << Update(
	With( Data Table( "Sales" ) ),
	Add Columns from Update table( :Name( "XX1" ) ));
eval(dtList[5]) << Update(
	Add Columns from Update table( :Name( "XX2" ) ))
many thanks
Alex is the name, Power BI/ SQL /JMP is my game
Re: Data table number to Data table name with contains and Eval
I think this will give you what you want
	If( Contains( Data Table( i ) << get name, "XX1" ),
		Break()
If( i <= N Table(),
	Data Table( i ) << Update(
	If( Contains( Data Table( i ) << get name, "XX2" ),
		Break()
If( i <= N Table(),
	Eval( dtList[5] ) << Update(
		Break()
If( i <= N Table(),
		Break()
If( i <= N Table(),
AlexS
Perfect thank you!
AlexS
@txnelson
how would I add a calculation to the table? I assume its something like
For( q = 2, q <= N Items( cols ), q++,
	For Each Row( cols[q][] = cols[q][] / :Name("xxx2") * 1000000 )
but I can't quite figure out how to put it in the code above?
using the code
	If( Contains( Data Table( i ) << get name, "xxx" ),
		Break()
If( i <= N Table(),
		Add Columns from Update table( :Name( "xxx2" ) )
many thanks for your help
Where does the variable "cols" come from.  Is it a List variable, containing the column name of each of the columns in the updated data table?
In your calculation, are you attempting to change the data in already existing columns, or are you attempting to create new columns in the data table?
AlexS
Cols is basically dt << get names then dt is current data table which I know might not be helping.
Change the data that’s there with the calculation then delete the new column added to make the calculation.
