RosDima
Data Table Filtering
Please see next code.
dt = Open( "$sample_data/big class.jmp" );
ages = Data Table( "big class" ) << Summary( Group( :age ), Freq( "None" ), Weight( "None" ) );
sexes = Data Table( "big class" ) << Summary( Group( :sex ), Freq( "None" ), Weight( "None" ) );
For( iage = 1, iage <= N Rows( ages ), iage++,
thisAge = ages:age[iage];
For( isex = 1, isex <= N Rows( sexes ), isex++,
thisSex = sexes:sex[isex];
Eval(
Eval Expr(
gb = dt << Graph Builder(
Size( 508, 438 ),
Show Control Panel( 0 ),
Variables( X( :weight ), Y( :height ) ),
Elements( Points( X, Y, Legend( 5 ) ) ),
where( age == Expr( thisAge ) & sex == Expr( thisSex ) )
Please explane me purpose of  Eval( Eval Expr
Thanks!
Re: Data Table Filtering
the line of code
has the memory variables embedded in the line.
     Eval Expr(.........)
takes all of the code with in the expression
	Size( 508, 438 ),
and will evaluate it, which basically will mean in this case, that it will replace the variable "thisAge" and "thisSex" with their current values.
The outside Eval() then takes the results of the Eval Expr and runs that code
The Eval Expr() function searches its argument for Expr() functions.  When it locates an Expr(), it evaluates the argument and replaces it with its value.  The outer Eval() evaluates the entire expression after that evaluation and replacement occurs.
For example from your script excerpt, when iage is 1 and isex is also 1, the code that is evaluated by Eval() looks like this to JMP:
Size( 508, 438 ),
where( age == 12 & sex == "F" )
Notice that the Where() clause above now has the variable values.
I encourage you to take a look at the article Expression Handling Functions: Part I - Unraveling the Expr(), NameExpr(), Eval(), ... Conundrum by Joseph Morgan for a much more thorough explanation.
I hope this is helpful!
Wendy
Wendy
the line of code
	Size( 508, 438 ),
Size( 508, 438 ),
Wendy
Wendy
