nmossery
Data Select within an object
Part of my script creates Varbility Charts that define by Two colums , "X" and "By" in the folowing way :
Global:PW <<  Append ( VCobj = Variability Chart(
                                        Y( Column( YCol ) ),
                                        By( BY( 0 ) ),
                                        X( XCol( 0 ) ),
Data table example :
Test
X
order
By
Y
T1
order
1
Test
50
T2
order
1
Test
60
T3
order
1
Test
70
in this case i will have 3 graphs that are seperated by the "By" Column , VCobj will contain 3 objects :
VCobj= {Variability Chart[], Variability Chart[],Variability Chart[]}
i managed to approach each object\graph by selecting VCobj[1] , VCobj [2] ETc...
i am trying to find a way of selecting all the data points within each graph in order to subset it to different data table for additonal calculations.
any idea how to do it ?
Thanks in advance , Noam.
Re: Data Select within an object
See Help > Books > Scripting Guide and search for "select where." This is the name of a message that you can send to the data table with a Boolean expression, such as By == 1, and so on.
Use Summarize() function to determine all the unique levels in the By variable and their order in the variability chart.
