BookmarkSubscribeRSS Feed
hupin
Community Trekker
Aug 11, 2013
Data Manipulate
Hi, I'm quite new in JMP. below is my raw data, they are squeeze in the same cell, each row is one lot information
any solotion to split and organize in nice order as below ? many thanks
Raw Data before:
re-organized raw data that I intend to get :
ms
Jun 23, 2011
Re: Data Manipulate
With such data, I think I would give the text file a grep-treatment before importing to JMP.
However try the script below. It should produce a new table with the data organized in different columns. It is assumed that there are no missing data, i.e. always the same number of entries in the same order.
col = Column( dt, "Raw Data" );
//Make list of names and data
L = Words( col[1], "();" );
//Define positions of data in L
m_data = (1 :: N Items( L ) / 2) * 2;
// Make list of column names
names = L[m_data-1];
n = N Items( names );
For( i = 1, i <= n, i++, names[i] = Trim( names[i] ) );
//Build matrix of all data
m = [];
For Each Row(
  L = Words( col[], "();" );
  L_data = L[m_data];
  L_data[i] = Num( L_data[i] )
  m ||= Matrix( L_data );
//Make new table
As Table( Transpose( m ), <<column names( names ) )<<set name("Organized Data");
hupin
Community Trekker
Aug 11, 2013
Re: Data Manipulate
thanks . but I'm not good at JSL, takes some time to digest
