hogi
Level XIII
Data Filter: sort by row()?
The data filter sorts the entries alphabetically or by number.
As an alternative, one can sort the entries by Counts:
Is there a setting to sort by row()?
e.g. when  a user adds new data and wants to see the last entry and the one before.
workaround:
generate a dummy column with "score_label"
Re: Data Filter: sort by row()?
Value Order can be used for this but it is annoying to manage unless you write your own functions (class is most likely best fit) for it.
Additional order options for data filters Allow user to select which summary statistic to use in data filters instead of just count
