BookmarkSubscribe
Israel_Haim
Community Member
Data Diffrence and screening
Hi All,
I would like to screen my data and evaloate the diffrence of two data set after screnning
example:x=yaers 1900:2000
y=tempurature
y2=seasons (winter spring  sammer autumn)
I would like to set only winter and summer
and see the diffrence bnetween the temparture in all the years
Thank you for reading
Israel
ian_jmp
Re: Data Diffrence and screening
I'm not sure if I have grasped exactly what you want to do. But you can set up more or less any 'analysis' you want (graphical and/or numerical) by running an appropriate platform (JMP menu item), then making use of the 'local data filter' to filter the contents of the resulting report.
To get started with this, take a look at:
http://www.jmp.com/support/help/13/Local_Data_Filter.shtml
ian_jmp
